yellowcab Posted May 23, 2020 Share Posted May 23, 2020 I would like to create a polygon from vertices in 3ds Max. When I try to create the polygon it says illegal new face. Any help would be appreciated. Thanks. Link to comment Share on other sites More sharing options...
Thomas Edward Allen Posted June 4, 2020 Share Posted June 4, 2020 Maybe try turning on snaps, create plane, make sure its aligned, then merge it with the original object. Also you can delete a face or two and extrude from an edge or bridge 2 edges. Link to comment Share on other sites More sharing options...
Qingyuan chen Posted August 16, 2020 Share Posted August 16, 2020 I have seen your question in another sites. A polygon can not be created from a non-open edge,which has two faces. So you can first use "split" to break the edge into two open edges Link to comment Share on other sites More sharing options...
