Alex Massey Posted August 6, 2020 Share Posted August 6, 2020 Hi everyone, new user here, I'm looking for some help with a couple of self learning projects I am working on. The only exterior light in the scenes are v-ray domes with an hdri loaded in it. However, to get the required light inside, they are bleaching out any objects that are outside the interior as well as the window frames. If I lower the intensity then the interior is too dark. Reducing the highlight burn only goes so far as well. Should I be only using an HDRI to externally light the scene or is there another preferred workflow that everyone uses? I'd really like the outside to be nicely balanced with the interior. Thanks in advance for any suggestions. Link to comment Share on other sites More sharing options...
Thomas Edward Allen Posted August 11, 2020 Share Posted August 11, 2020 Reduce the brightness of the hdri and work on your interior lighting - or try a different hdri. Peter Guthrie's are great, and are always getting re-balanced by him which is nice. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 17, 2020 Share Posted August 17, 2020 This is a natural phenomena actually, if you take your cellphone and take a similar photo it will look exactly the same, even with a pro camera. This is because the lighting difference between the exterior and the interior. or the difference of intensity between interior lighting and exterior. This been talked many times in this mere forum. To make a 'more balanced' image you need to increase the intensity of your interior lights and adjust your exposure and color mapping accordingly. You can do this in the VRay frame buffer or save the image ad HDRI or EXR and correct in post. 1 Link to comment Share on other sites More sharing options...
TomD_Arch Posted August 27, 2020 Share Posted August 27, 2020 On 8/17/2020 at 5:26 PM, Francisco Penaloza said: This is a natural phenomena actually, if you take your cellphone and take a similar photo it will look exactly the same, even with a pro camera. This is because the lighting difference between the exterior and the interior. or the difference of intensity between interior lighting and exterior. This been talked many times in this mere forum. To make a 'more balanced' image you need to increase the intensity of your interior lights and adjust your exposure and color mapping accordingly. You can do this in the VRay frame buffer or save the image ad HDRI or EXR and correct in post. What he said! Was just going to say all that. Link to comment Share on other sites More sharing options...
