Arnel Posted January 1, 2005 Share Posted January 1, 2005 Need some help here guys. Our viz 2005 used to work just fine and then recently all of a sudden it will just hang during start up. It will hang while loading mental ray.dlz plug-in. Already tried uninstall then reinstall but still the same problem. Link to comment Share on other sites More sharing options...
Fernando Lino Posted January 1, 2005 Share Posted January 1, 2005 I have the same problem, yesterday it was working well...I am using fR-1 and Vray...after loading the component I got the message that "An error has occureded and the application will now close" I re-installed it and nothing happen!!....maybe it is the internal conection thru the internet with the Autodesk's server... they have the day off today, the last person yesterday turned the lights off,un-pluged the server and the IT monkeys are drunk Link to comment Share on other sites More sharing options...
Fernando Lino Posted January 1, 2005 Share Posted January 1, 2005 This is a public apologies for the IT monkeys in Autodesk....they are not drunk...or yes they are!!, who knows but It wasn't their fault, it is a vray issue, I installed vray 1.46.10 and now Viz is working!!! I found the thread under vray forum...the good news are the server is working and lights are on Link to comment Share on other sites More sharing options...
M_Jaco Posted January 2, 2005 Share Posted January 2, 2005 see link http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=4753152&linkID=982821 Link to comment Share on other sites More sharing options...
Fernando Lino Posted January 2, 2005 Share Posted January 2, 2005 Yesterday it was working my Viz for few hours, I've tried different ways to resolve the problem. I un-installed Vray, re-installing VIZ and it doesn't work is anybody here has the same problem? Link to comment Share on other sites More sharing options...
Arnel Posted January 3, 2005 Author Share Posted January 3, 2005 see link http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=4753152&linkID=982821 Thanks for the link ill give it a try and post the outcome when im done. Link to comment Share on other sites More sharing options...
Arnel Posted January 3, 2005 Author Share Posted January 3, 2005 Disabled karspersky anti-hacker program but that does not solve our problem. I cannot think of any other program blocking the mental ray port. So I followed the next instruction to go to user's configuration and here is my problem (excuse my ignorance) where can i access that users configuration? How should we know which program is interferring with the mental ray port 7001? Link to comment Share on other sites More sharing options...
Fernando Lino Posted January 3, 2005 Share Posted January 3, 2005 Arnel I think it is more than that, I have worked with VIZ without any problem for months and after new year this happen, 1st was a Vray issue but new I don't know, today I'll try to find the solution out. Autodesk Should do something about it. Link to comment Share on other sites More sharing options...
abicalho Posted January 3, 2005 Share Posted January 3, 2005 Fernando (I am double posting cause others are here). Remove all 3rd party plugins and try again. VIZ is working fine here @ home and in my laptop. I do not have any plugins installed. Alexander Discreet Quality Engineer Link to comment Share on other sites More sharing options...
Arnel Posted January 3, 2005 Author Share Posted January 3, 2005 Already uninstalled vray but still the same. It hangs while loading mental ray.dlz How to access user's configuration and how to check which program is blocking mental ray port 7001? Any help is pretty much appreciated. Thanks Link to comment Share on other sites More sharing options...
M_Jaco Posted January 3, 2005 Share Posted January 3, 2005 Did you check in the task manager if there aren’t any processes of the anti virus program running? Sometimes even if you unload the program some processes are still running, if you find some kill it Also, you can rename mantelray.dlz in the stdplugs folder, and VIZ should load, but of course you won’t have mantel ray. Link to comment Share on other sites More sharing options...
Fernando Lino Posted January 3, 2005 Share Posted January 3, 2005 You do need to un-install VIZ and erase the folder, after that you can install VIZ again with the new components. Link to comment Share on other sites More sharing options...
Arnel Posted January 4, 2005 Author Share Posted January 4, 2005 Disabled antivirus, anti-hackers and vray plug-in then uninstall-reinstall viz 2005 but still the same problem. Rename mental ray.dlz to any other name resolved the issue. But I still have to test it if it will not affect anything during production time. Link to comment Share on other sites More sharing options...
