Andrew _GF Posted August 26, 2021 Share Posted August 26, 2021 (edited) Hi. Andrew here from GarageFarm.NET Academy. I have a new tutorial to share. The topic has been covered many times, but even if you are experienced user you may find a cool trick which you didn't know. I added the link to the new version of the video in the last comment. Edited January 26, 2022 by Andrew _GF Link to comment Share on other sites More sharing options...
Tom Bussey Posted September 1, 2021 Share Posted September 1, 2021 just use F5/6/7/8 for axis constraints. Good vid though Link to comment Share on other sites More sharing options...
Andrew _GF Posted January 25, 2022 Author Share Posted January 25, 2022 (edited) Thank you Tom Bussey ------------------------------------ Michał here from CG BBQ YT chanel. A new video about customizing 3ds Max UI for archviz is coming! We published it some time ago on GarageFarm.NET Academy, but an updated version is going to appear on the CG BBQ channel devoted only to 3ds Max tutorials. (Academy was mostly about Blender) Unfortunately, I went crazy in the process of making the remake. https://www.youtube.com/watch?v=IMYRZquJDXg See you soon! Edited January 25, 2022 by Andrew _GF Link to comment Share on other sites More sharing options...
Andrew _GF Posted January 26, 2022 Author Share Posted January 26, 2022 (edited) Hey. We published the final tutorial video. Hope you will find it useful. 18 steps to customize 3ds MAX UI for archviz projects (updated) In this tut, Andrew shows how to customize 3ds Max for modeling architecture. You will learn how to get rid of useless panels taking away precious workspace. Hotkeys and quick buttons will speed up your workflow. Other settings will help you manage your scene and work with the precision required in archviz. Finally, you will learn how to save your setting so you can switch between various UI setups and move them to a different 3ds Max installation! Timestamps: 00:00 - Introduction 00:09 - Setting up System Unit Scale 01:39 - Setting up Display Unit Scale 02:13 - Adding Hotkeys for Views 04:18 - Adding Hotkey for Measure Distance tool 04:39 - Adding Hotkey for Convert to Editable Poly 05:09 - Setting up Snaps 05:34 - Changing default Reference Coordinate System setup 05:56 - Customizing Toolbars and Panels 06:21 - Turning off the ViewCube 06:25 - Adding Layer Explorer 06:31 - Adding quick buttons for Modifiers 07:04 - Locking UI layout 07:25 - Adding more scene Undos 07:43 - Extending Auto Backup interval 08:01 - Turning on automatic Cross/Window selection 08:38 - Expanding Command Panel 09:10 - Turning off Preview Highlights 09:27 - Changing the Vertex size 09:44 - Saving customizations 09:52 - ENU folder 10:03 - maxstart.max scene 10:20 - Quickly reverting to default settings 10:58 - UI customization saving options in 3ds Max 11:07 - Saving workspaces 11:36 - saving UI from Customize - Save Custom UI scheme 11:56 - Custom Defaults Switcher 12:17 - Summary 12:32 - Custom settings paths in 3ds Max 12:39 - Useful Hotkeys See you in the next one! Edited January 26, 2022 by Andrew _GF Link to comment Share on other sites More sharing options...
