Morne Erasmus Posted November 20, 2021 Share Posted November 20, 2021 Hi Guys If I'm not planning on overclocking, are there any specific settings I should be paying attention to, or can I basically set everything to default in the BIOS? ASUS Dark Hero, AMD Ryzen 9 5950X Also, do you guys install all the utilities and monitoring that come with the board, or do you prefer only the chipset drivers? Link to comment Share on other sites More sharing options...
Scott Schroeder Posted November 23, 2021 Share Posted November 23, 2021 I built my PC recently and just kept the default bios settings. I may look into some of the features of my motherboard in the near future, but I wanted to make sure everything worked before tweaking anything. If there are some better monitoring tools for temps and such, I would imagine those would be good to have. Outside of that, I'd say the chipset drivers are the more important ones. In all of the PC's I've built, I've kept the bios at default settings because like you, I don't overclock anything. I probably should look into it, but it's not a big priority at this point. Link to comment Share on other sites More sharing options...
Morne Erasmus Posted November 25, 2021 Author Share Posted November 25, 2021 Ive been running everything on default, except disabling all wireless settings in bios. Seems fine(ish) so far. Idle temps are around 36 or so, with the occasional clock and temp spikes between 55 and 61 degrees (celcius), for no apparent reason while simply browsing. Apparently this is normal, but still a little weird to me as this is my 1st AMD system (been using Intel for 30 years!) Link to comment Share on other sites More sharing options...
