Sawyer Posted January 6, 2005 Share Posted January 6, 2005 I was asked to rewwork a 3 year old project. A cad operator modeled the building in cad and from what I can tell booleaned everything. What I am left with is a spaghetti mesh with lines everywhere. I can post a wire frame later but what I need to be able to do is model gable ends where the original has a barrel roof. Any ideas? Thanks Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted January 6, 2005 Share Posted January 6, 2005 I was asked to rewwork a 3 year old project. A cad operator modeled the building in cad and from what I can tell booleaned everything. What I am left with is a spaghetti mesh with lines everywhere. I can post a wire frame later but what I need to be able to do is model gable ends where the original has a barrel roof. Any ideas? Thanks can you cut the model? ...can you cut the tops of the buildings off, and just model the tops. of course you have already thought of this. Link to comment Share on other sites More sharing options...
joseph alexander Posted January 6, 2005 Share Posted January 6, 2005 Photoshop. if you can't cut up the roof, model the gables directly over it and composite the two renders in photoshop, one of just the gables and one of the old model. I'm not sure what the materials are though, so lining up tiling may be an issue. Link to comment Share on other sites More sharing options...
Sawyer Posted January 6, 2005 Author Share Posted January 6, 2005 can you cut the model? ...can you cut the tops of the buildings off, and just model the tops. of course you have already thought of this. I think thats the first thing I will try. I seem to remember having problems cutting geometry that has all these narrow triangles. Maybe it will work fine I will give it shot tonight. Link to comment Share on other sites More sharing options...
Chad Warner Posted January 7, 2005 Share Posted January 7, 2005 If you are using Max or VIz, you should be able to use the slice modifier on the building without any problems. -Chad Link to comment Share on other sites More sharing options...
