Is there a way to turn off vray?
smartsheep
Hi, it takes really long time to launch 3dsmax, with an empty file, after I installed vray. (Before 20s, now 2 mins with vray installed)
I was wondering if there's a way to turn off the vray plugin if I'm recently just doing modelling work? Many thanks in advance!
Indeed it is , you have to rename the PackageContents.xml file in the...\ApplicationPlugins\Vray3dsMaXXX folder ( xxx schould be your 3ds Max version ).  eg. rename it to PackageContents.xml_ or similar
the ApplicationPlugins folders location i think is depending on your  setup, see for a description here
https://help.autodesk.com/view/MAXDEV/2023/ENU/?guid=packaging_plugins
But after you renamed the xml file, 3ds max should not load vray any longer at launch
Edited by Josef Wienerroither
  • Like 1
Expand
Hi Josef, thank you so much for sharing the link! I just tried to move away vray-related files in both the location you mentioned and the other location where max was installed, it worked really well!
