PRIYAN PATEL Posted January 9, 2024 Share Posted January 9, 2024 Hello ! I have an issue with previewing the geometry in 3ds max in perspective viewport It is disappearing and not previewing when i working or set some landscap System units are not problem beacuse i check with all unit Also there is issue with gizmo in perspective only, that it doesn't move smoothly but in steps. System units are not a problem because I check with all units. Is there some solution for this ? below two image one image is perspective and one image is orthographic Link to comment Share on other sites More sharing options...
James Vella Posted January 9, 2024 Share Posted January 9, 2024 This is actually to do with system units. When working with large scenes meters is your best option otherwise you get z-fighting in perspective view. If changing units is not an option (since it will break lots of things such as real-world units and modifiers) then use the orthographic view. Link to comment Share on other sites More sharing options...
PRIYAN PATEL Posted January 9, 2024 Author Share Posted January 9, 2024 Thenks James Vella, but not working those i solution Because when I copy some thing and bring another empty Max to work, Even so problem comes, WITH PERSPECTIVE viewport, in orthographic working good but i dont use that viewpoint beacuse doesn't fit, chek out below image, the whole max was empty just this flooring things in max,However, there is a problem Link to comment Share on other sites More sharing options...
James Vella Posted January 11, 2024 Share Posted January 11, 2024 When you copy it into the new scene, is that new scene also in meters? Link to comment Share on other sites More sharing options...
