Ravendark Posted January 11, 2005 Share Posted January 11, 2005 Hello all, Using AutoCad2004 i have drawn a room, using the AEC blocks for walls, windows etc. When i import this dwg file into Max6 each object, for example is split into various layers as shown in the screen shot here "max6 layers.jpg". However, when i import the same dwg into max7 (using the same import options as i did using max6) objects are not split into layers. So for example, instead of having seperate layers for the glass, frame and sash in the case of a window, max7 keeps the entire window object on one layer. I know i can apply materials using id's and multi-sub objects but obviously this is more time consuming. Has anyone else noticed this problem or could anyone let me know if there is a procedure which will allow me to import to max7 in a way where all the AEC layers are visible, thanks in advance. Link to comment Share on other sites More sharing options...
abicalho Posted January 11, 2005 Share Posted January 11, 2005 Hi there, You need to install the ADT 2005 Object Enabler in your system in order for MAX 7 to be able to translate the ADT data. You can download it here: http://www.autodesk.com/oe Hope it helps, Link to comment Share on other sites More sharing options...
Ravendark Posted January 11, 2005 Author Share Posted January 11, 2005 That's worked a treat! Thankyou very much abicalho. Link to comment Share on other sites More sharing options...
