dave davidson Posted June 20, 2006 Share Posted June 20, 2006 if someone scans it in there is my scanner is out of order at the mo or i would have done it Link to comment Share on other sites More sharing options...
AJLynn Posted June 20, 2006 Share Posted June 20, 2006 That's just as well, copyright violations are frowned upon Link to comment Share on other sites More sharing options...
Ernest Burden III Posted June 20, 2006 Share Posted June 20, 2006 That's just as well, copyright violations are frowned upon In that case, we should expect Victor to post it on the NL forum any minute now. Link to comment Share on other sites More sharing options...
Richard McCarthy Posted June 20, 2006 Share Posted June 20, 2006 Magnus the Maximus3D use Maxwell with 3DS MAX !! MAX MAX MAX !! Link to comment Share on other sites More sharing options...
Richard McCarthy Posted June 20, 2006 Share Posted June 20, 2006 in all countries were it was a tyrant, all the people who oppose him hardly where imprisoned or killed, and the others were exiled or mocked. For the people that have recognized the tyrant as a saviour, they believed words like "its all going well...don't believe them !!!" story has theached us that, so we know how will it end...with a BLOOD BATH. eheheheheheheh LMAO Blood Bath.. sounds like a new shampoo from Chanel.. where can I buy it? Link to comment Share on other sites More sharing options...
Ernest Burden III Posted June 20, 2006 Share Posted June 20, 2006 Magnus the Maximus3D use Maxwell with 3DS MAX !! MAX MAX MAX !! Are the bars open extra late there, Richard? What prompted that? Magnus also uses Rhino and Cinema4D. Could be others! Link to comment Share on other sites More sharing options...
Fran Posted June 20, 2006 Share Posted June 20, 2006 Richard, I'm not a moderator anymore. But please moderate yourself and avoid lampooning others. Link to comment Share on other sites More sharing options...
JDHill Posted June 20, 2006 Share Posted June 20, 2006 Beta vs. V1: material translation -> testing the wizards: beta |t: 30.2h | sl: 21.69 v1 |t: 12.37h | sl: 15.16 notes: - original res. 1600x600 on 2 cores - v1 materials created with wizards using identical parameters as beta [except vinyl siding - lost material] - v1 glass is wizard-created AGS - not set to be reflective enough, IMO - see transom above coat closet ...figured since it was a architectural-type image, I'd post here. Constructive input welcome...the v1.1 wizards are still being improved. ~JD Link to comment Share on other sites More sharing options...
Guest imanobody Posted June 20, 2006 Share Posted June 20, 2006 I think what people want to see is the same interior lite by interior lights or a bright sun that will illuminate the whole room. Those images are really too dark to accurately judge bounce light. IMHO Link to comment Share on other sites More sharing options...
Devin Johnston Posted June 20, 2006 Share Posted June 20, 2006 I agree, what people want to see are some of the WOW images that were being produced by the beta to be reproduced by V1. I want to see if V1 is at least capable of replicating those kinds of images and how long it takes to do it. These two images look virtually identical with the V1 image looking like it has a little less noise. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted June 20, 2006 Share Posted June 20, 2006 These two images look virtually identical with the V1 image looking like it has a little less noise. They are far from virtually identical. The v1 image has much better definition in low-light areas, like the base board at the bay window and the railing. The secondary bounced light is easier to notice, too, making the beta version look flat in areas like the door jambs (where the sun is hitting right at their base). The reduced noise is pretty obvious, but the other differences are there. One simple point is that the v1 image has much better contrast which would partially explain the differences, but not completely. Look at the door panels, the wall intersection at the upper right. So its the same engine but its not the same engine? Link to comment Share on other sites More sharing options...
JDHill Posted June 20, 2006 Share Posted June 20, 2006 Well, this is what I've got for now...so if you've got any ideas...fire away. For example, I think the bump on the doors is too strong in the v1 image, and although it's a taste issue, the finish on the doors is a bit better in the beta image. ~JD ...oops, hi there Ernest. You're correct...the 2 engines are similar, but in a world of code...to call them 'the same' engine would be extremely short-sighted. Link to comment Share on other sites More sharing options...
Devin Johnston Posted June 20, 2006 Share Posted June 20, 2006 Your right Ernest the V1 image is just a little bit lighter than the beta. Link to comment Share on other sites More sharing options...
Maximus3D Posted June 20, 2006 Share Posted June 20, 2006 Richard McCarthy: I thought moderators were supposed to be adults, apparently there not all of them seem to be so which you so nicely proved to us all in your post there. Ernest & Frances: Thanks both of you / Magnus Link to comment Share on other sites More sharing options...
Adehus Posted June 20, 2006 Author Share Posted June 20, 2006 You're correct...the 2 engines are similar, but in a world of code...to call them 'the same' engine would be extremely short-sighted. In the world of users, what's the difference? I'm not asking to be a contrarian, but when a company makes improvements to their software (assuming they're actually improvements) they're usually not shy about explaining what's new/different/better. NL certainly hasn't been shy about trumpeting the virtues of their material editor, even in spite of it's less than warm reception. So what's the deal with the 'new' engine? Link to comment Share on other sites More sharing options...
Richard McCarthy Posted June 21, 2006 Share Posted June 21, 2006 Sorry, I apologise if I offended you, I was just joking Hey, feel free to lampoon my avatar too !! Link to comment Share on other sites More sharing options...
Richard McCarthy Posted June 21, 2006 Share Posted June 21, 2006 Are the bars open extra late there, Richard? What prompted that? Magnus also uses Rhino and Cinema4D. Could be others! Nothing, bad humour I guess... My fault.. Link to comment Share on other sites More sharing options...
Richard McCarthy Posted June 21, 2006 Share Posted June 21, 2006 Richard McCarthy: I thought moderators were supposed to be adults, apparently there not all of them seem to be so which you so nicely proved to us all in your post there. Ernest & Frances: Thanks both of you / Magnus Sigh, it's like trying to argue with a bunch of trolls.. although trolls would make more sense than you guys do. But i get the message, i'll shaddap from now on unless i have something negative to say. Thanks / Max I was just humouring you for the fact you were calling everyone on this board trolls irregardless of whether we have actually reply to you or not. Maybe my humour has opposite effect of someone who have no sense of humour, then again, if you disregard people's feeling by calling people and bystanders trolls AND disregard of other people's opinion, maybe you should not expect to afford the same respect others have for you. Link to comment Share on other sites More sharing options...
giacob Posted June 21, 2006 Share Posted June 21, 2006 maximus, a nice guy on the whole, had the difect of playing the role of the mirth victime which is not.....because he often attack others with much violence and without having been attacked ( a remark to nl cant be considered an attack to him)... Link to comment Share on other sites More sharing options...
leoA4D Posted June 21, 2006 Share Posted June 21, 2006 Rendertaxi is a decent renderer and he has updated his gallery over at the forum: http://www.maxwellrender.com/forum/viewtopic.php?t=6265. This is an interesting comparison of v1 (images 1 & 2) and beta (3 & 5) results using identical images. The remarks, starting at the end of page 5, are amusing – the gloves are on. Link to comment Share on other sites More sharing options...
ivox3 Posted June 22, 2006 Share Posted June 22, 2006 Yep, I think I was the first to reply on that one. Just to follow up on what I said about adding in some A-leveling and contrast. I took the time to do it. My version of the V1. Hope Alex(rendertaxi) doesn't mind. Link to comment Share on other sites More sharing options...
Fran Posted June 22, 2006 Share Posted June 22, 2006 Richard, considering the circumstances, I guess there are worse things than lampooning an avatar. Link to comment Share on other sites More sharing options...
AJLynn Posted June 22, 2006 Share Posted June 22, 2006 ...And considering Richard's avatar, there are much more entertaining ways to respond... Link to comment Share on other sites More sharing options...
ivox3 Posted June 22, 2006 Share Posted June 22, 2006 I would just like to know that we're no actual animals hurt in the production of Richard's avatar. Then I could finally go to sleep and know that everything is right in the world. Link to comment Share on other sites More sharing options...
AJLynn Posted June 22, 2006 Share Posted June 22, 2006 http://www.museumofhoaxes.com/pranks/bonsai.html Unfortunately the original site is down. Link to comment Share on other sites More sharing options...
