danb4026 Posted May 17, 2008 Author Share Posted May 17, 2008 Got DR working great! Knocked my rendering times in half. Link to comment Share on other sites More sharing options...
Eric Sosa Posted May 19, 2008 Share Posted May 19, 2008 (edited) I'm glad u finally made it Daniel as for the dark spots....hum, welcome to "Distributed Rendering issues" dunno if u have fixed, but u got to have ALL your maps located in a single place where all pc's connected have acces to. ligths, vraysetup, default vray mats, etc are NOT affected by the slave(s) machines...so u should not see darker ligthining in the slaves buckets, but u may see black or gray spots in those buckests if the slave machine can NOT read or have acces to the maps location. well, u made it mate......ENJOY YOUR DOBBLET SPEED WHEN RENDERING!! . Edited May 19, 2008 by Eric Sosa Link to comment Share on other sites More sharing options...
danb4026 Posted May 26, 2008 Author Share Posted May 26, 2008 script: renderers.current.system_numThreads=4 this script is for quad cores machines, therefore the nr. 4 at the end Eric, if you are using 2 quad core machines as part of the DR, would the script have and "=8" at the end? Link to comment Share on other sites More sharing options...
Eric Sosa Posted May 26, 2008 Share Posted May 26, 2008 Eric, if you are using 2 quad core machines as part of the DR, would the script have and "=8" at the end? not, no. 4 = MAXIMUM cores found in the system....and u have only quad cores. btw..is it everything ok with DR now Daniel? Link to comment Share on other sites More sharing options...
danb4026 Posted May 26, 2008 Author Share Posted May 26, 2008 Eric, everything seems to be working just fine, except for one error message I get in the Vray Message window when rendering: "Could not connect to host 192.168.0.199: No connection could be made because the target machine actively refused it" The target machine is my host machine. I have the firewalls all off, so I do not know what is causing the problem. I have searched and searche for a resolution, to no avail. The rendering seems fine and I can see the buckets containing the ID's of the Host and Slave machines rendering, but I still get that error. I dont know if it means anything or not. Any ideas? Link to comment Share on other sites More sharing options...
Eric Sosa Posted May 26, 2008 Share Posted May 26, 2008 Daniel, I stated before, the vray messenger window is NOT very trustfull...(DR bug, or whatever we can call it) what I mean, (again), if ALL the pc's connected CPU works at 100%, then it means DR is working properly and the render develops FINE. if one of the pc connected is NOT running with 100% (at least at rendering), THEN, there is a problem. I find out that by simply copying/paste the script and successfuly finding the pc's IP in the "resolving renders" of the DR window setting, the DR works fine again. Very confusing is the vray message window. hell, hope it gets fixed in the new vray versions, do NOT trust it...completely. Link to comment Share on other sites More sharing options...
danb4026 Posted May 26, 2008 Author Share Posted May 26, 2008 Thanks Eric, I will not trust that message window then. Everything seems to work fine, so I will assume the message window is in error. The cpu's work at up to 100%, but not all the time. They go up and down but definitely hit 100%. Link to comment Share on other sites More sharing options...
Eric Sosa Posted May 26, 2008 Share Posted May 26, 2008 ....but definitely hit 100%. it works Link to comment Share on other sites More sharing options...
hi2shiva Posted July 31, 2008 Share Posted July 31, 2008 Thanks to both eric and daniel for explaning the concept of distributed rendering . now i am using 3 quad systems for dr. and still i feel its taking too much of time to single render and i need to make walk through. so please give some tips to fast rendering. using 3 system its almost taking 6mins each frame. help needed to speed up my renders Thanks and Regards shiva Link to comment Share on other sites More sharing options...
maumau Posted August 9, 2008 Share Posted August 9, 2008 hi all. i have a question about DR: do i have to start/stop the spawners in the rest of my machines to reset them? i found it quite often that the remote desktops are BUSY, so what i have to do is to exit the spawner there and restart it, but i would like to know if there is something i am missing or not doing. i would like to have a much more trusthworkhy DR situation here. are there some "better" practices for Vray DR? thanx!! Link to comment Share on other sites More sharing options...
danb4026 Posted August 9, 2008 Author Share Posted August 9, 2008 So you're using remote desktop to start spawner on your slave machines? There should be no need to exit and re-open spawner, but occasionally I do that if there are any problems to reset things. Do you have your Vray Message window open to see error messages while rendering? Link to comment Share on other sites More sharing options...
maumau Posted August 10, 2008 Share Posted August 10, 2008 hi dan. i use it to restart it, actually. what i found is that if i wait, say 2 minutes, i don't have to restart it. as for the mssg window, i don't get errors, but a warning about my server being busy. i guess i am just being too impatient with it. it if let it erm... autorecover (?) it works fine and i don't have the need to restart the spawner. i guess i just have to aknowledge that it takes a bit of time. thanx! Link to comment Share on other sites More sharing options...
Eric Sosa Posted August 11, 2008 Share Posted August 11, 2008 use VNC viewer, the master and slaves are alreay in a network...it's just easy to control all those things Link to comment Share on other sites More sharing options...
rafa rubio Posted February 28, 2009 Share Posted February 28, 2009 3d max 2009+vray 1.5 sp2 perfect DR Link to comment Share on other sites More sharing options...
vj13vj Posted April 30, 2009 Share Posted April 30, 2009 Hello to you all this is my first post here. I have a question about v-ray DR, Is it possible to make 20 PC (quad cores) work together in a single frame with Distributed Render, because i'm able to connect only 9 slaves when i try to add the 10th slave than errors says " Missing Maps" etc.. Can i make 20 PC work together on a single frame ? Thank You Link to comment Share on other sites More sharing options...
rafa rubio Posted April 30, 2009 Share Posted April 30, 2009 i heared before that is not possible... just 10 pc.. Link to comment Share on other sites More sharing options...
aaronrumple Posted May 5, 2009 Share Posted May 5, 2009 Hello to you all this is my first post here. I have a question about v-ray DR, Is it possible to make 20 PC (quad cores) work together in a single frame with Distributed Render, because i'm able to connect only 9 slaves when i try to add the 10th slave than errors says " Missing Maps" etc.. Can i make 20 PC work together on a single frame ? Thank You Yes. You'll first need 2 licenses for Vray as each license is limited to 10 systems. You'll also need to make sure that maps are all located on a server. Based one your specific error - I'm guessing you have the maps on a workstation. Windows workstations allow for up to 10 connections. If more systems try to connect, they will be refused and you'll get missing maps. In that case - move your maps to a Windows server. Link to comment Share on other sites More sharing options...
gfriedman Posted September 27, 2009 Share Posted September 27, 2009 i finally got vray dr up and running and though i am getting no error message in the vray msg window - it says its connected and says something about sending the model over - but the buckets only have the name of the master computer I h?e started the file with. what gives? also my computer seems to be choking even with nothing rendering....strangest thing Link to comment Share on other sites More sharing options...
vj13vj Posted September 27, 2009 Share Posted September 27, 2009 thanks for the tip aaronrumple, (Y) Link to comment Share on other sites More sharing options...
jingyit Posted September 29, 2009 Share Posted September 29, 2009 humm, don't realy understand what you want DR to do for you. DR = several computers connected on a local network to render one single frame. if you do not get the 100% of the CPU of each machine, what is the point of having them to run together?, then, simply make each machine render one frame on it's own. lets put it this way: one "dual core" pc can render a frame in 60.0 min on it's own, 2 x dual core pc's, working with DR, can render the same frame in 30.0 min, 10 x dual core pc's, working with DR, can render the frame in 6.00 min!!...this is the advantage of rendering with DR DR gives you the chance to render one single frame FASTER by using several computers networking. back to topic; script: renderers.current.system_numThreads=4 this script is for quad cores machines, therefore the nr. 4 at the end. dual cores would use nr. 2 fo example. about your computers specifications.....dunno if you can us this script with a nr. 1 at the end or you simply need other specific script. more advanced members may help here good luck daniel , you'll be very happy of you make it work this way. greets Eric Hi Eric (or anyone else who might be able to help!), I've tried out the script on both my quad core machines, and while it worked for a while, (all CPUs show 100% for a couple of renders) subsequently the slave machine goes back to running at only 23%. At the same time, the vray dialogue box tells me that "it could not connect to render host" and then connects and transfers the scene again. I can't seem to get this to go away despite re-booting both my computers and running the script again. Can anyone help? Link to comment Share on other sites More sharing options...
davidanderson Posted July 3, 2012 Share Posted July 3, 2012 I have a question too about this. My Host has 6 cores, and a slave has 8, and another 4. So should the script be script: renderers.current.system_numThreads=8 ? Would that be correct? That is what I tried and I noticed that all machines are using 100% for the most part, but there are certain periods where they will drop to less than 50%, but then go back up to 100%. Is that expected? The other issue that I'm having is that I get an error message about the host "warning: Could not connect to host 192.168.0.195: No connection could be made because the target machine actively refused it." Oddly enough though, the host does show up in the render buckets, so it is working, but why I get this error, I don't know. Thanks Dave Link to comment Share on other sites More sharing options...
charlieinolas Posted September 26, 2012 Share Posted September 26, 2012 (edited) Hi all here, I'd some advice guys. I work on max 2012 64-bit with vray 2.0, win 7 64bit. Generally I need to speed up my renders and would like to use my sister's laptop to help me out. I realized, that connetecting through wifi would be nice solution to let her use some basic stuff like internet, so I installed max on her laptop launch Vrayspawner and all seems to be good at first. Distributed render in small window shows connected, vrayspawner is on on my laptop, but while my desktop renders, I can only see 4 squares with the name of my desktop. Desktop is connected to router with cable, and laptop to router through wifi. It looks that all is ok, there're no warnings in the render window, it says 'connected'. any suggestions ? thanks! Edited September 26, 2012 by charlieinolas Link to comment Share on other sites More sharing options...
davidanderson Posted September 26, 2012 Share Posted September 26, 2012 Seems like you should be getting *some* error message? And you're sure that you have Distributed Render checked in your Render prefs and that the IP of the two laptops is in there? For me, my issues was a firewall thing. I eventually was able to fix the issue. Link to comment Share on other sites More sharing options...
charlieinolas Posted September 26, 2012 Share Posted September 26, 2012 (edited) No errors...that's why it's weird. I have no firewalls here. I'll check this out again, but don't think so. It's even written 'scene transfered to..' but finally I see only 'squares' that belong to 'desktop'. Edited September 26, 2012 by charlieinolas Link to comment Share on other sites More sharing options...
John Dollus Posted September 26, 2012 Share Posted September 26, 2012 her laptop also has win 7 64 bit? just making sure you don't have vray 32 bit installed on the laptop. Link to comment Share on other sites More sharing options...
