SunGlare Posted September 11, 2009 Share Posted September 11, 2009 Hello, I looking to bring down render time of this image. Please give some ideas how to do this. I also suspect that there might be some tricky switch somewhere, beceause scene is rather simple (except xref 230mb tree) IrMap: low LC: 400, 4pases ImageSampler: DMC min:1 max:2 AA: Mitchell-Netraval and it turn out to be 4.5 hours! on quad intel q8200, 8gb, asus. at first it was crashing after it reached 5.6gb, but then I found this dynamic memory 400MB limit, and set it to 7GB. also some spots showed upupper left area?, also it is bit too dark, so I think I need to convert to gamma workflow(nightmare) one direct light, enviroment ovrd 2.0, vray sphre wth light mtl inside(as a sky) ____________________________________________________ To summ up: 1. What do you thik about render time of it? 2. Where the color pixels coming from? 3. Is there easy way to convert scene form non managed to gamma2.2? 4. How do you like it, what you see? Help me. Boys and Girls. Link to comment Share on other sites More sharing options...
STRAT Posted September 11, 2009 Share Posted September 11, 2009 do you only have LC gi? Link to comment Share on other sites More sharing options...
SunGlare Posted September 11, 2009 Author Share Posted September 11, 2009 Primary: Irritating Map Secondary : Lite Cash Link to comment Share on other sites More sharing options...
STRAT Posted September 11, 2009 Share Posted September 11, 2009 sorry mate, missed that Link to comment Share on other sites More sharing options...
BrianKitts Posted September 11, 2009 Share Posted September 11, 2009 Primary: Irritating Map yes some times it can be.... Link to comment Share on other sites More sharing options...
Nic H Posted September 11, 2009 Share Posted September 11, 2009 vray sphre wth light mtl inside(as a sky) sounds weird use a phys cam / sun sky and try reinhard color mapping. Link to comment Share on other sites More sharing options...
jkrock3d Posted September 11, 2009 Share Posted September 11, 2009 Hey sunglare, I have some suggestions try switching off the displacement map for the wall. Secondly... I see your glass roof has glossy reflection try increasing the value say .85. By doing this u will at least know which one is causing problem right? Lastly since there's not much visible detail beyond the roof get it rendered in separate layer and comp it with blur filter. One more step(sorry about that) usually objects like trees with opacity maps or heavy meshes take lot of time to render, so try disabling shadows for the tree!! HOpe these makes sense. JK Link to comment Share on other sites More sharing options...
SunGlare Posted September 11, 2009 Author Share Posted September 11, 2009 So... to sum up... ...any thoughts on the subject? Link to comment Share on other sites More sharing options...
jkrock3d Posted September 11, 2009 Share Posted September 11, 2009 We can "Sum up " only if u let us know whether u solved your problem mate!! Did you try those adjustments? Link to comment Share on other sites More sharing options...
SunGlare Posted September 11, 2009 Author Share Posted September 11, 2009 Thanks, jkrock3d: I was impatient and posted it before your posts. I need wall dispace, need glass blur on that level decreasing it will cause floor look too transparent, there is nothing beyond roof, so no need for layer-render. I will take a closer look at shadows as I have pretty small shadow threshold, in order to show some tiny brickwork on the outside. I'll try to turn of shadows for that tree, and adding some shadow mask, to see if will help. Where those weird pixels coming from? huh... sun gamma radiation outburst? but I dont use sun, as my skin is rather pale. Thanks Link to comment Share on other sites More sharing options...
jkrock3d Posted September 12, 2009 Share Posted September 12, 2009 Sunglare u got me wrong, Am just saying disable the settings so as to find out which one is eating up more time to render! Try to understand what we want to achieve here go step by step u say there's nothing beyond the roof, i guess u got me wrong there too.. i meant the glass ceiling where ur other (upper)floor is. We can see through some furnitures right? what are those? U said it you are impatient my friend!! JK Link to comment Share on other sites More sharing options...
