Problem Child Posted January 13, 2010 Share Posted January 13, 2010 Hi, I have a problem in Vray Advanced (Full Version) 3ds Max 2010. Whenever I hit render,it renders just a black screen in Vray render:confused:.Can anyone help me? please! Link to comment Share on other sites More sharing options...
andrejcordeiro Posted January 13, 2010 Share Posted January 13, 2010 Good morning, you have to confirm the position of the camera, if it is within an object, the image comes out black. This might be the problem. But also I am assuming here, since I do not have a pre-Visualization of settings. Link to comment Share on other sites More sharing options...
hughie Posted January 13, 2010 Share Posted January 13, 2010 can you give a bit more info on your scene setup? could be that you are using a vray camera with the low light setting. Link to comment Share on other sites More sharing options...
sanmb Posted January 14, 2010 Share Posted January 14, 2010 Check the position of the camera.It should not be iside the object. Check V-ray settings. Good Luck. Link to comment Share on other sites More sharing options...
Problem Child Posted January 23, 2010 Author Share Posted January 23, 2010 Can anybody tell me where I can find the Vray cam? Yours Sincerely Problem Child Link to comment Share on other sites More sharing options...
hughie Posted January 24, 2010 Share Posted January 24, 2010 Hey try on the right hand panel, Create>Cameras and on the drop down go from Standard to Vray, you will find it there. Later Hugh Link to comment Share on other sites More sharing options...
Problem Child Posted January 28, 2010 Author Share Posted January 28, 2010 It is not there I checked it. Link to comment Share on other sites More sharing options...
erickdt Posted January 28, 2010 Share Posted January 28, 2010 Is the VRay license server running? Link to comment Share on other sites More sharing options...
dheersreedh Posted January 29, 2010 Share Posted January 29, 2010 hi this thread was i am waiting for... i was working in max 9 till last week... now i jumped in to 2010 yhe same problem i am facing... the file which i was rendering in max 9 is not rendering in 2010... it shows the black screen any changes in v ray settings needed? please give me the setup detailes... Link to comment Share on other sites More sharing options...
mienq.blom Posted January 29, 2010 Share Posted January 29, 2010 sounds like an installation problem to me. Maybe try reinstall vray? Is your vray compatible with Max 2010? Otherwise try & contact Chaosgroup. Link to comment Share on other sites More sharing options...
