dancsank Posted February 26, 2010 Share Posted February 26, 2010 Hi I am an architecture student who needs help before a review. I am using rhino with a maxwell plugin. All I am trying to do is add an image to a maxwell material which I can then tile and make transparent so I can just see the objects behind it. I have tried every option from reflectance, transmittance, nd, roughness, attenuation and mapping the image in each category with no results. All I would like to know is what are the settings and steps to map a jpeg image into a material and then have it be transparent (the same transparency level as like a photoshop image at 70 percent opacity). The surface has no thickness but can go up to 1" if it has to have a thickness for attenuation or whatnot. I really appreciate the help this could save my tons of hours photoshopping. Thanks Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted February 26, 2010 Share Posted February 26, 2010 Page 53 in the manual. I'm sure there's all sorts of interesting stuff, but I didn't read it. I didn't even test it in a render ;-). But the material preview looks OK so it should be at least a start. Link to comment Share on other sites More sharing options...
