Animation: rendering to single frames (many),joining them efficiently and compressing
Tomasz79
Hi. I`m rendering camera flythrogh type of animation in 3ds Max and V-Ray. It is 1800 frames, one minute and I render each frame to single file, png files, 640x480. I cannot render it to avi in one single take, since I have to use the computer for something else meanwhile, and stop the rendering from time to time.
If it was shorter, I would load it all in RAM Player, all the frames and used Save As afterwards, choosen AVI and compression type. However, it is too much for my RAM (2Gb, under Win XP) and those frames can not load all together. I would appreaciate any help, as to how to do it simply, any recommended free programs that can join single image files into movie files, or perhaps I could load in Ram Pl. half (900) frames and save it as uncompressed file, load second half, save as part 2 and in another program join thosae big uncompressed avis into one, compressed one?
Another thing is, I don`t want to loose any more quality than nessesery in this joining and compressing process, and that is also the reason why I ask, since perhaps someone understands it all better and can give me a hint. In Ram player, there are not much comp[ression options, like cinepak radius, or indeo video, and oin both situations when I test it on smaller frame counts, results (compressed avis) are not great, anyone got any good ways of compressing avis / mpgs or movs? Thanks for your time.
- Tomek
Hello
You can use quicklime pro and load the frame sequence into the player, then go to export, and make sure the settings are set to "Animation"(raw codec) for no compression, or h264
I won't render to avi through max. ONLY render frames and then put them together afterwards
g'luck
A
