Architectural glass reflections
Allypander
Hi,
I've been working on this rendering for a few days and it's nearly there. I just cant get the reflections right in the glass panes.
Could anyone suggest why the panes have their own reflections, rather than a realistic overall reflection (not explaining myself very well but hopefully clear in the attached image). Most apparent in the foreground doors.
I'm using an HDRI background/environment.
Vray with 3d Max
Glass mat settings:
Refraction = Nearly white, IOR = 1.52
Reflection = full white with fresnel, gloss val = 1,
Cheers
[ATTACH=CONFIG]46146[/ATTACH]
double check if your glass has a thickness. if it is a single plane, without any volume it could create some "lens distortion effects" like you see. another thing you can do is to check is there is a smoothing problem on the surface. simply apply a smooth modifier and check "autosmooth" with the default values
Thanks for your suggestions guys.
I did try your recomendations, but to no avail.
I then played with the background settings, which (I think) is where the problem lay.
I have now changed the Vray reflection/env. to a bitmap rather than an HDRI image. I have manually offset the image tiling (U-axis) in the material editor to get a reasonable perspective. Unfortunately the reflections dont realistically relate to the lighting.
I realise this is a bit of a bodge job, but can just about get away with it in this case.
Updated version:
[ATTACH=CONFIG]46265[/ATTACH]
