stayinwonderland Posted December 17, 2011 Share Posted December 17, 2011 (see attached). I've been following the V-Ray Advanced Webinar from 3dats. I've tried everything but a) my shadows are too dark (do you agree?) and b) the ground is really bleached and burned out. What I have: Physical camera, Vray Sun, irradiance map and light cache. What I've already tried: Tweaking many differing color mapping settings. The values don't seem to change anything much at all, even when I put in quite drastic numbers. I'm very new to Vray (just started today) so if you could go easy on me with the ol' prior knowledge Link to comment Share on other sites More sharing options...
AubreyM Posted December 17, 2011 Share Posted December 17, 2011 Color mapping won't help with your shadows, you need to tweak the vray sun settings. Here is a link that explains the different settings. http://www.spot3d.com/vray/help/200R1/examples_vraysun_sky.htm I usually stick with Reinhard and a burn value of .5 or so. Link to comment Share on other sites More sharing options...
stayinwonderland Posted December 18, 2011 Author Share Posted December 18, 2011 That's a good overview of the sun. So cheers for that. But it doesn't really talk about shadow levels. The best compromise I came up with was increasing the 1st light bounce to 1.6 to get more light moving around, then I manually tweaked the RGB output of the grass to tone it down. Does this make sense? Link to comment Share on other sites More sharing options...
AubreyM Posted December 18, 2011 Share Posted December 18, 2011 No not really. I almost never take the bounces over 1.0 but that is just me. I think you will need to play with the Vraysun settings in combination with the camera settings to get the effect you are looking for. I can't give you settings because each scene is different. The big ones for the sun are z height, size and intensity. Good luck Link to comment Share on other sites More sharing options...
stayinwonderland Posted December 18, 2011 Author Share Posted December 18, 2011 Ok then, i'll see what I can do. Thanks for the tip Link to comment Share on other sites More sharing options...
Ismael Posted December 18, 2011 Share Posted December 18, 2011 Check the pictorial by tush bobo in the following link: http://www.nairaland.com/nigeria/topic-172090.224.html Does it give you an idea about your dark shadows? Also see what controls and what they do in the VraySun and the VraySkylight: http://www.spot3d.com/vray/help/150SP1/vraysun_sky_param.htm#parameters_sun Link to comment Share on other sites More sharing options...
stayinwonderland Posted December 19, 2011 Author Share Posted December 19, 2011 Thanks for the links Link to comment Share on other sites More sharing options...
