hobgob Posted March 28, 2012 Share Posted March 28, 2012 Studio/Institution: GBClient: Villa GroupGenre: Office InteriorSoftware: SketchUp - 3ds Max - PhotoshopDescription: This is a work in which I have been involved these last days. I have not defined materials. Since I wanted to focus on views and light. The task is an office. Link to comment Share on other sites More sharing options...
datacrasher Posted March 29, 2012 Share Posted March 29, 2012 a bit over exposed When adding a light i always use the active shade because this automatically update in you're p.view click and hold the render button you willl get a drop down and click the render when the red teapot this is active shade when you increase or decrease the lights max will update you're scene. Do get it back to the normal renderer then do the same click and hold on the renderer box and click the first one Link to comment Share on other sites More sharing options...
hobgob Posted March 29, 2012 Author Share Posted March 29, 2012 Thanks for the advice, cheers Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted March 29, 2012 Share Posted March 29, 2012 You should correct the verticals. Without this, vertical lines start to take too much weight, visually, from your image and it will be difficult to tell if your framing is right or not. You also have an image that would be a good candidate for aligning a vertical to one of the horizontal thirds. Set your safe frame to display the thirds and try it. I think you'll find a lot more balance. Lastly, the over brightness is definitely just the light source. The exposure looks decent everywhere else. Maybe a little under exposed actually. Good Luck. Link to comment Share on other sites More sharing options...
