Hair and Fur problem
kasyensz
Guys,
Im making a bedroom and i need a carpet. With the new vray (2.20.2+ 20.3) is it possible for 2012 users to render the hair and fur modifier.
When im trying to render it, it always shows the fur above the plane :S ( see the picture)
I tried many settings and i just cannot make it work!!
Somebody any tips?
Cheers
PS: cheating isnt possible, if i place the plane under my floor the hair will not show at all ;)
By default, a percentage of hairs are displayed in the viewports, but surface-grown guides do not appear except when you are working at the Guides sub-object level. You can adjust the viewport display of guides and hairs with settings on the display rollout
Guides are also used to calculate dynamics. After this calculation, hair interpolation takes place when you render. This is when parameters such as Frizz, as well as displacement and coloration, are calculated. You don't have control of every single hair, but this two-phase process makes the creation of realistic hair computationally feasible on a typical computer.
Do you have any modifiers applied to the plane? I think that parameters like frizz and displace (by the way this would be my first guess for your problem) don't have to be calculated. They have nothing to do with dynamics...
