vray problems
jmcumming
I've been using maxwell for rendering but heard vray has much faster render times. I'm currently doing a linear workflow tutorial but already have some problems!
I've mapped the building but it comes out terribly in the render. However the map seems fine in a test scene. The settings are the same. I'm confused
http://dl.dropbox.com/u/35530999/problems/test02.jpg
http://dl.dropbox.com/u/35530999/problems/test%2001.jpg
Any help would be super!
using linear workflow,you should use the vray frame buffer.there is a button at the bottom " srgb" check that and your render will show the gamma 2.2. different ways on using linear workflow, but I find that if you set max's gamma to 2.2 and the output to 1.0, vray gamma ( render dialog) 2.2 and check " don't affect colours" that should work.hope that helps.
