Environments Tab Disappeared
Chris8173
Hi Guys,
Fairly new to these forums so not to sure if this is the correct place to post a problem for 3ds max.
Im having issues trying to find the evironments rollout in the rendering drop down section of 3ds max (number 8).
When i click it, for some reason the environments tab doesnt appear on my screen. Its ticked.. but no window :S It was fine the other day, and now it just doesnt appear on my screen at all. I have two screens and it isnt on the second one either..
Someone please help :(
what happens if you do it the normal way by going to rendering and effects menu? if this does not work then i would restart max reboot you're computer and start it max again see if it appears if not then i would locate the max.ini file and delete it and restart you're computer and autodesk will replace it.
i don't know where the new versions are it should be located at C:\Documents and Settings\username/\Local Settings\Application Data\Autodesk\3dsmax - 32bit or 64 bit\enu
The window is probably open, but sitting offscreen. Did you change your monitor config recently maybe ? eg. from 2 to one monitor or so ?
Anyways, to bring back your dialogs, i recommend the following script
http://www.scriptspot.com/3ds-max/scripts/give-me-back-my-dialogs
It let's you bring the various Max dialogs back to the currend monitor...
