wrong horizontal lines on caustic Vray rendering
duduchier
Hi,
I am trying to render caustics on a flat plane.
I get wrong regular strait horizontal lines. Here are some setting :
-- direct light with caustics subdivs at 400000
-- "Indirect illumination" set to OFF
-- "Caustics Multiplier" set to 100000 (!)
-- "Max photons" and "Max density" set to 0
I get different distance between those lines depending on the rendering resolution.
Since lines are regular, I thought it was a memory problem. Setting "Dynamic memory limit" to 0 and changing "render region division" does not solve the problem.
The problem seems new because it was not occurring last year.
I'm using V-Ray 2.30.01 and 3ds max 2013, all on 64 bits under Windows 7.
Here is what I get :
Thanks !!!
hi,
I did not found the reason for the problem but I found a way to avoid it with my special case.
Errors (strait lines or regular wholes depending on the render definition) from the caustic are seen along the structure of the plane I am sending light onto. Although the plane is only one segment, caustics errors show the existence of segments. I do not know what they are.
The size of the scene was very very big. I could get rid of the errors when changing its size back to a few centimeters or meters. At least, I do not see them anymore at any output definition.
I have to add that I am not rendering only the caustic elements but I use rather use the "do not render until the end" option. I do not know why but results are better for what I want.
