rhlkvr15 Posted September 10, 2012 Share Posted September 10, 2012 Hi, good day guys, Can any professionals please explain how to get light bounces in vray as shown in the image (red marked), especially in the corners of the white wall, just confused if it is some kind of material settings or Render settings that created such effects. i need to create those effects. hope to get a favourable reply...... thankyou....... Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted September 10, 2012 Share Posted September 10, 2012 That is not so much an effect as it is likely an error. What you see are "light leaks." It is likely that the person who modeled that building did so without closing up the back of it and the sun is making its way through the building. It is also very likely that rather than shelling the walls, the modeler only used extruded splines. If you are just looking for light scalloping on your walls, try an IES light. The most common file should be easy to find, it's call "nice1"- just google for it. The whole point of AO/Dirt is that light darkens at corners and therefore the "effect" you are seeing is the exact opposite of what should be going on. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted September 10, 2012 Share Posted September 10, 2012 That's not an effect you'd see in real life unless that surface was a highly reflective metal and that would only happen in the direct sun light. It would never occur on the shaded side of the building. As Corey said, it's more than likely a Vray error, be it a light leak or incorrect GI bounce. Why do you need to create something that would never really happen in real life? Link to comment Share on other sites More sharing options...
Nic H Posted September 11, 2012 Share Posted September 11, 2012 id say the diffuse value of that material is too high - or its bad irradiance map setting Link to comment Share on other sites More sharing options...
Chris MacDonald Posted September 11, 2012 Share Posted September 11, 2012 Why are you trying to immitate a render artifact/error? Link to comment Share on other sites More sharing options...
rhlkvr15 Posted September 11, 2012 Author Share Posted September 11, 2012 really appreciate for the reply guys...thank you very much.....but here in the local world some people like those kind of artifacts...thats the problem i got.......actually i have a bunch of images with those artifacts....and was trying to get those but failed always.......anyhow got to convince clients...... but if anyone know how to make low GI settings to create such artifacts especially on the corners of white wall please reply.... thank you once again.... have a great day.... Link to comment Share on other sites More sharing options...
