lucaslucas Posted November 6, 2012 Share Posted November 6, 2012 Hi everyone, I'm getting a strange situation here and hope you can help: I have installed 3ds max on a computer here in the office and it is only running either while logged in the built-in admin account or if I run the program as administrator (right-click > run as administrator) be it in a standard account OR an administrator account other than the built-in. What happens when I try to launch 3ds max is that a process (3dsmax.exe) is started and hangs with about 11.200k, with no warnings or errors whatsoever. Trying to find out what´s happening, I went to the local appdata 3dsmax folder and realized that the program can´t create the startup files: the folder structure is created up to the ENU folder, and then nothing else. If I run it as admin, though, the whole structure is created and the program runs normally. I tried to copy this structure to the analog standard user folder, but nothing happens. I also tried to mess with folder ownership and privileges, but everything seems ok, the user has - obviously - full access to the local appdata folder. I´m using windows 7 and I have to have UAC on and need to have Max working for a standard user with no admin privileges. My basic system specs: • Intel i5 2500k • Radeon HD7850 • 60gb Corsair SSD as cache disk on a 500gb standard disk • 16gb RAM Thank you very much. Link to comment Share on other sites More sharing options...
lucaslucas Posted March 16, 2013 Author Share Posted March 16, 2013 Well, after a long time struggling with the matter, today I accidentaly found out what was causing the problem: Lucid Virtu MVP, a bloatware that came with my mobo. Just disabled it and now everything is fine! Regards, LUCAS Link to comment Share on other sites More sharing options...
