How should I assign a fabric material?
mohammadebrahimian
The pattern would be changed by changing the map/texture, they are lots and lots available freely on the net. Get something with larger resolution to avoid repetition. But the image doesn't look that bad as you put it out :); and yes, modelling the sheets and pillows better could do the magic in them.
This process of continuous ongoing improvement is like modern day unbiased renderers, it ain't over till you force it stop because you have to hand it over to the client.
turn off any reflectivity, and drop a falloff map in your diffuse map. then duplicate your current map in both slots, set the color swatches to white and then turn down the bottom maps percentage to 50 or so that way as it falls off to glancing angles it desaturates and goes white. Will give your fabric a realistic sheen.
