etayu Posted January 5, 2013 Share Posted January 5, 2013 Recently,i'm working on an architecture animation,and i find out rendering a cluster of trees with VR2side mtl is very painful.... the tree that i use have at least 80,000 polygon My question is which is the best solution for trees in Close-up and Long Shot?and it must be realistic. Thanks! Link to comment Share on other sites More sharing options...
bartjole Posted January 6, 2013 Share Posted January 6, 2013 did you already try VrayProxy? Because that helps a LOT! Link to comment Share on other sites More sharing options...
etayu Posted January 6, 2013 Author Share Posted January 6, 2013 bartjole said: did you already try VrayProxy? Because that helps a LOT! Of course,but it still have to calculate a lot of opacity map and it take me a lot of time..... Link to comment Share on other sites More sharing options...
bartjole Posted January 7, 2013 Share Posted January 7, 2013 What system do you have? Thats the first thing the render time depends on. The main problem besides the polygons and system is the material. For the trees which are not in closeup, pick a simple material with a lowres texture, no bump, specular etc. maps. Maybe you have to pick an other tree model if you duplicate them a lot. I also recommend using a scatter plugin, such as multiscatter. Link to comment Share on other sites More sharing options...
bilderbaurendering Posted January 7, 2013 Share Posted January 7, 2013 hello Yu, have you ever tried RPC trees? (sure you need RPC plugin ) it saves a time .) Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 7, 2013 Share Posted January 7, 2013 Calculating opacity maps takes no time at all if you make sure "Filtering" is set to "none", rather that pyramidal/summed. Link to comment Share on other sites More sharing options...
etayu Posted January 7, 2013 Author Share Posted January 7, 2013 Thank you for all your help! Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted January 8, 2013 Share Posted January 8, 2013 2 side material requires longer render time, because is 2 side material! now this is not that bad, but is the price that you need to pay if you want better transparency, now what you can do is separate all your trees as Close up trees, Medium and background, then only apply 2 side mat to the close ups trees, then simple transparency to the second layer and maybe not transparency at all to the very background all depend of your hardware, maybe you can render the tress in a separate layer or so. Link to comment Share on other sites More sharing options...
