Tsiki Posted January 17, 2013 Share Posted January 17, 2013 Hello, I'm using Max 2010 with Vray 2 My problem is the VrayHDRI in my scene. The Horiz. rotation works as expected and I can turn the HDRI as I need. I have a problem with Vert. roatation. When I'm start change the rotation level I can see the HDRI rotate like it has a pivot on scene left side instead of move it up or down as expected. Please advice for any idea why it moves like this. Regards, Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted January 17, 2013 Share Posted January 17, 2013 what type of mapping are you using? vrayhdri doesn't support max standard mapping. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted January 17, 2013 Share Posted January 17, 2013 I think he is referring to the horizontal and vertical rotation controls within the Vray hdri map. Those controls refer to world axis's which is why the vertical rotation acts "funny". It's rotating exactly as expected. You really shouldn't need to move your hdri map up or down. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted January 17, 2013 Share Posted January 17, 2013 Yeah. I caught what he meant. I was reading the Spot3D page on VrayHDRI and noticed that basically nothing worked properly with Max Standard Mapping. Doubt it is the answer, but figured I would put it out there. True on the "shouldn't need to move your HDRI up and down." If the map doesn't have a horizon at mid point, you can always set the map to offset by 0.5 and then untick tiling in the vertical direction. or just double the height in PS then add a black base. Link to comment Share on other sites More sharing options...
Tsiki Posted January 19, 2013 Author Share Posted January 19, 2013 Thanks. I'm using HDRI sphirical mapping type. On the Coordination section I'm using Environ mode with sphirical environment mapping. In my scene I need to change background vertically as it shouldn't show the grass from the 3rd. floor appartment I'm rendring. It works OK for horizantal rotation. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted January 19, 2013 Share Posted January 19, 2013 Just do it in post. Set your background to be on the alpha channel and just replace it in Photoshop or other program. It's so much easier to do it in post. Link to comment Share on other sites More sharing options...
Tsiki Posted January 19, 2013 Author Share Posted January 19, 2013 Yep. I keep this option as last. I have window blinds in my scene so it should be easy in MAX Link to comment Share on other sites More sharing options...
