richardbuelna Posted February 21, 2013 Share Posted February 21, 2013 Have anyone had this problem before? It appears that the glass is reflecting a black circle that I suppose is something from the camera.."camera range" I dont know.. its just a black circle that follows the movement of the camera.. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted February 21, 2013 Share Posted February 21, 2013 What is your environment map? It also could be geometry. You might try just rebuilding your glass. Link to comment Share on other sites More sharing options...
richardbuelna Posted February 21, 2013 Author Share Posted February 21, 2013 I have a Vray sky as enviroment map but. I closed the max scene.. then opened again. use a new vraycamera.. and dissappear.. I dont know what the f**... thanks anyway. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted February 22, 2013 Share Posted February 22, 2013 Could be to do with the reflection cutoff value in your glass material, it's under options. Try lowering it to 0.001 and see. Link to comment Share on other sites More sharing options...
