Tsiki Posted July 11, 2013 Share Posted July 11, 2013 (edited) I have ~ 50MB .skp Sketchup8 file. I need to import this model to MAX 2010. Export to .3ds fails (reports somthing about Temp directory size, which I have plenty). I tried export to - FBX (1,500 MB) - DEA (53 MB) - DWG (58 MB) None of those exported file types completes import action. Any type I'm using cause my MAX to freeze. Any idea why it's happening? Which different way I should use for export skp so I'll be able to import in MAX? Edited July 11, 2013 by Tsiki Link to comment Share on other sites More sharing options...
Ismael Posted July 11, 2013 Share Posted July 11, 2013 http://sketchupdate.blogspot.com/2010/10/sketchup-to-3ds-max-anyone.html Link to comment Share on other sites More sharing options...
Tsiki Posted July 11, 2013 Author Share Posted July 11, 2013 (edited) Thanks. Inside link to the connection_extension tool is broken. I'll look for it elsewhere. Update: Download link: https://rapidshare.com/#!download|968p1|276533377|connection_extension_3dsmax.exe|26367|0|0|1|referer-5CED7B84308C22F79DCB4082ED9BE6A3 I have it installed and it works like rocket. Thank you very much Edited July 11, 2013 by Tsiki Link to comment Share on other sites More sharing options...
unrinoceronte Posted July 14, 2013 Share Posted July 14, 2013 Without using that, have you tried selecting the IMPORT BY LAYER option? when the by ENTITIES is selected it takes more time to import since there will be many indinvidual objects... Link to comment Share on other sites More sharing options...
