trinacranadia Posted November 11, 2013 Share Posted November 11, 2013 Hi you all! I use Skecthup with Vray to render 3d. I would like to get a metal fabric aspect for a material. I used a texture, diffuse (with transparency) and reflection layer. For reflection I utilized 2.0 for TextFresnel options (IOR) and 1 for Glossiness. In preview mode the material used looks good, as I would want to see it. But the material seems to not have the same performance in rendering. I attach an example of render and material preview. The objects with this material are solid components, with a thin depth (2 cm). Link to comment Share on other sites More sharing options...
Ciro Sannino Posted November 12, 2013 Share Posted November 12, 2013 Hi Trinacra, my suggestion is start finding a photoreference, then compare them to evaluate if your simulation is going on the right way it could seems a stupid-basic suggestion, but in my opinion in this that most of time make the difference. In case you already have a real photo as reference... could you post it? Link to comment Share on other sites More sharing options...
trinacranadia Posted November 12, 2013 Author Share Posted November 12, 2013 Sure! I can understand what you suggest and I am in agreement. I would have a metal/pierced effect like this. Similar to Steven Holl's architecture in Amsterdam (Sarphatistraat Offices). Link to comment Share on other sites More sharing options...
CliveG Posted November 12, 2013 Share Posted November 12, 2013 (edited) Is there anything else in the scene to reflect? Perhaps you should fine tune your material (referring to your reference photos) in something like the BBB3 sample scene (or SU equivalent) to be able to get a better idea of whether the material is at fault or your scene? Edited November 12, 2013 by CliveG Link to comment Share on other sites More sharing options...
trinacranadia Posted November 12, 2013 Author Share Posted November 12, 2013 first thank you both! @Ciro I posted an example, as you suggested. I suppose the comment is under moderation mode. I try again. @complete-newbie The scene is clean and I tried a different texture, with same characteristic on layers of vray. The same results. Mmm what do you mean with BBB3? Could you please explain this to me? --- Link to comment Share on other sites More sharing options...
trinacranadia Posted November 26, 2013 Author Share Posted November 26, 2013 plis some help? Link to comment Share on other sites More sharing options...
