adding normal map to material
hoseinasadi
Add a Normal Bump map to the Bump slot of your material and put your normals map in the Normal slot. There you can use an additional bump map.
You could also put a Mix map in the bump slot and combine Normal Bump and whatever bump map. For me, first option works best.
thanks alot for the tip. :)
