Vray Warning Texture Map
philipdutoit
Hi all,
I'm having the following warning when I'm rendering:
"warning: Texture "Map #12514780" caused an exception."
Is there a script or something available to find this map? The scene is very big with alot of maps which makes it very difficult to find.
Any help will be appreciated!
Thanks in advance
  • 3 months later...
Go into the slate editor. In the main tabs select the "Material" tab and then click "Get all scene materials".In the main panel bottom left corner you should see a pair of binoculars, click this. Now type in your map name word exactly as is is written including spaces. Now click the green box next to the where you have typed in your map name. This should now locate the map.
