HELP!! Problem of vray for C4D when save image sequence
tomli
I meet a problem when I try to render an animation using vray for cinema 4d R15, all things look good in the 'Picture Viewer' of cinema, but when I check the image sequence from my output folder, I find they are all BLACK image, nothing was good except the last frame of the sequence. I guess there is some problem when cinema save the image sequence.
In the beginning I thought maybe it was caused by IR map, so I turn off GI for a test, the problem still was there.
After that I try to render in some different situation for test, then I got these:
when I render a single frame (for a still image), I will get a normal result.
when I render an animation sequence, e.g. a ball moving animation in 20 frames, I will get a normal sequence result.
when I render an animation sequence with a vray physical camera, problem comes, image_0 until image_19 are all black, but image_20 is good.
Then I delete the physical camera tag and give a try, Problem has gone.
It looks like the vray physical camera can be a problem when render sequence. Anyone meet the same issue? Any solution?
OS X 10.9.2
VRAY 1.8.0
  • 7 months later...
  • 9 months later...
