satyafouzdar Posted August 21, 2014 Share Posted August 21, 2014 hey everyone ...im trying to render my exterior scene but render output is black screen. im using vray sun n vray physical camera..can anyone help me to fix this. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted August 21, 2014 Share Posted August 21, 2014 looks like your camera exposure is off. Start with: F - 16 Shutter - 50 ISO - 160 and then you should be able to get brighter or darker results by raising and lowering the F value. I also would un-tick Vignette. Link to comment Share on other sites More sharing options...
satyafouzdar Posted August 21, 2014 Author Share Posted August 21, 2014 Nothing happening .....with these camera setting its still black Link to comment Share on other sites More sharing options...
Ismael Posted August 21, 2014 Share Posted August 21, 2014 V-Ray what version? Newer versions have, http://help.chaosgroup.com/vray/help/200R1/vray_exposure.htm My version is 1.5 and all exposure is done with the Physical Camera only. I have to make sure to not turn Max exposure control on. Link to comment Share on other sites More sharing options...
satyafouzdar Posted August 22, 2014 Author Share Posted August 22, 2014 yeah im also using 1.5 vray...and all exposure settings are right ...but dont know whats going on.. Link to comment Share on other sites More sharing options...
jayeshmane Posted August 22, 2014 Share Posted August 22, 2014 check out you are material setting may be in mental ray or some other Link to comment Share on other sites More sharing options...
satyafouzdar Posted August 22, 2014 Author Share Posted August 22, 2014 no its vray materials .... Link to comment Share on other sites More sharing options...
jayeshmane Posted August 22, 2014 Share Posted August 22, 2014 try with the 3ds max standard camera Link to comment Share on other sites More sharing options...
DanGrover Posted August 22, 2014 Share Posted August 22, 2014 Also check your global switches - it's easy to turn lights off! Link to comment Share on other sites More sharing options...
harryhirsch Posted August 22, 2014 Share Posted August 22, 2014 The output looks like a single render pass (illumination?) to me... Link to comment Share on other sites More sharing options...
Ismael Posted August 22, 2014 Share Posted August 22, 2014 Are you using a Max Daylight System with your V-Ray Sun? Maybe you have the sun too low in the horizon... You need calculate GI also. Link to comment Share on other sites More sharing options...
zuwinnadi Posted August 22, 2014 Share Posted August 22, 2014 Try duplicating your camera, renaming the duplicate and re-rendering. Happens to me sometimes in Max 2014 and this technique works for me. Link to comment Share on other sites More sharing options...
