donloller Posted February 20, 2015 Share Posted February 20, 2015 Hello, I use 3DS Max 2015 with Vray 2.5. In my following problem I use Vray Lights and a Vray Camera. Please see the attached picture. On the picture (red mark) is a reflection from my vray light. But I do not want to have a reflection on my TV. How can I disable the reflection (just for the TV)? Or is it a problem with the material, do I have to change there something? Thank you for your help Link to comment Share on other sites More sharing options...
donloller Posted February 20, 2015 Author Share Posted February 20, 2015 Please help, I have tried everything without success. If you look closely on the picture you can see, that the glasses are reflected as well (right bottom) Why??? Link to comment Share on other sites More sharing options...
k-ram Posted February 25, 2015 Share Posted February 25, 2015 Hello Don, I guess this should have been posted under VRay . In Max you can right click on any object and untick "visible to reflection/refraction." This should solve your problem, (or; if you don't want any reflections at all on the object, you could assign a black value in the reflection slot of your material). Hope this helps - Link to comment Share on other sites More sharing options...
