andrejaleksov Posted July 27, 2015 Share Posted July 27, 2015 Hi, I have a stupid question. When I check the bloom effect on, in V-ray 3 lens effects window, after rendering process, there is a message "No channel, please re-render!". I can do it in post-production, but I want to do it in the vray frame buffer. It makes me crazy, because it's the simplest thing I don't know. Please help. Thank you. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted July 28, 2015 Share Posted July 28, 2015 Do what it tells you. You need to re render after activating the lens effects. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted July 28, 2015 Share Posted July 28, 2015 As Scott said, VRay needs to know to generate a "glare/bloom" render element before it can apply any effect to the finished render. Enable it BEFORE you render. Link to comment Share on other sites More sharing options...
jair_gh Posted August 4, 2015 Share Posted August 4, 2015 Hello everyone, I rather post it here than create a new thread. I am working with the VrayLensEffects and I only get to see it if I disable the Vray Frame Buffer and I use 3ds max native one. I have searched all over the internet and tried looking into the parameters but I just cannot get it done. I don't know what is the problem. Thanks for your help. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted August 5, 2015 Share Posted August 5, 2015 The one in effects no longer works. Enable the vray frame buffer, open it, and there should be a button that is called lens effect settings. Click it and you will get a similar menu to the one in the Effects tab. Fill in the same values you had from the effects tab, and re render. Then it should work. Link to comment Share on other sites More sharing options...
mouarffff Posted August 6, 2015 Share Posted August 6, 2015 Hi everyone, Same thing here I have another question related to all that and don't think I need to create a new thread for that. When I use the VrayLensEffect (until now) I bake it into my renders but this doesn't give me the level of control I'd like to have. So I tried not to bake it and render the passes but don't understand how to compile the passes in photoshop to get exactly what I'd get in the VFB, do any of you work with the passes instead of baking it in the render ? Thanks ! Chris Link to comment Share on other sites More sharing options...
Scott Schroeder Posted August 6, 2015 Share Posted August 6, 2015 You need to set the mode to lighten in PS on your bloom and glare render elements. This isn't a 1 to 1 match as you would get in the VFB, but with some opacity adjustments on the bloom element it's close enough. If you want a 1 to 1, combine your base layer(s) and your bloom render element layer into a smart layer. Then go to layer -> smart objects -> stack mode -> and set it to mean (ie average in other apps) and this gets you pretty much exactly what you see in the VFB. See the first half of this vid about stack modes and smart objects. Link to comment Share on other sites More sharing options...
mouarffff Posted August 6, 2015 Share Posted August 6, 2015 You need to set the mode to lighten in PS on your bloom and glare render elements. This isn't a 1 to 1 match as you would get in the VFB, but with some opacity adjustments on the bloom element it's close enough. If you want a 1 to 1, combine your base layer(s) and your bloom render element layer into a smart layer. Then go to layer -> smart objects -> stack mode -> and set it to mean (ie average in other apps) and this gets you pretty much exactly what you see in the VFB. See the first half of this vid about stack modes and smart objects. Thanks Scott it sounds good I'll give it a try ! Link to comment Share on other sites More sharing options...
