Noise In Trees - Aerial View
rhlkvr15
Hi Forum,
I have been working on a architectural walkthrough, and when rendering the aerial view I get these noise on Trees, Please help me out with this and also do find the link below to view the video. And also attached render setting for GI and Final Renders.
(This video is the final output - 1280X720)
thankyou...
Hard to tell from the video compression, but I think I know what you meant.
Your adaptive image sampler seems too low, when I do animations I can go from 2-6 to 2-8 or 2-10 depending. Dealing with antialising in small geometry/Textures it is hard for the engine. Also remember to create a velocity pass, that will also help to "hide" that flickering of antialising crawlling over your trees.
Thank You very much Francisco Penaloza for the quick reply...Very helpful information, I will try to render with higher samples and compare the renders.
I Would really appreciate if anyone please let me know the LC and IR map settings I have been using are correct or should I have to make any changes.
Thank You........
Edited by rhlkvr15
