ashoksingh Posted January 20, 2016 Share Posted January 20, 2016 Hello, i created a environment in 3ds max with itoo forest pack plugin (i use vray proxy model) and in the final stage trying to convert forest plantation (proxy mesh) into mesh, i am facing problem that the mesh is not visible proper. i have attached the image below, (in right side image is vray proxy and left is converted forest mesh). and also my file size is increasing. kindly a give solution. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 20, 2016 Share Posted January 20, 2016 You need to change your forest display settings to show the mesh before you convert it to one, otherwise you'll just end up converting a point cloud or box or whatever to a mesh. Link to comment Share on other sites More sharing options...
ashoksingh Posted January 20, 2016 Author Share Posted January 20, 2016 Hi chris, Thanks for the reply, your solution is working on normal mesh but i am using the vray proxy mesh inside the custom object. in this case mesh is not visible in render. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 20, 2016 Share Posted January 20, 2016 Inside the what? Custom object? Link to comment Share on other sites More sharing options...
ashoksingh Posted January 20, 2016 Author Share Posted January 20, 2016 hi i have attached the screen shorts u can understand the problem. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 20, 2016 Share Posted January 20, 2016 Right, so the geometry you have used in forest pack is the VRay Proxy? Switch the Vray Proxy AND forest pro to display mesh. You may have to update/refresh the geometry in forest pro, but it should work. Link to comment Share on other sites More sharing options...
ashoksingh Posted January 20, 2016 Author Share Posted January 20, 2016 Chris - am using the forest pack lite version. Will it work here? Could you please explain a little detailed- perhaps step by step? Doing this for the first time Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 20, 2016 Share Posted January 20, 2016 Set the Vray Proxy to "show whole mesh". Then set forest pro to display "mesh". Then you can convert forest pro to an editable mesh. Link to comment Share on other sites More sharing options...
ashoksingh Posted January 20, 2016 Author Share Posted January 20, 2016 Chris - am using vray 3.00. Looks like the "show whole mesh" option is available in version 3.3. How to work this out? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 20, 2016 Share Posted January 20, 2016 download version 3.3 from the chaosgroup website? It's a free upgrade from 3.00 Link to comment Share on other sites More sharing options...
