joaomatos1 Posted February 4, 2016 Share Posted February 4, 2016 Hi there! I have a problem with the reflections (I think). It has the appearance of a reverse ambient occlusion, and occurs in my ceiling, which is "floating" a few centimeters above the beams. What can be causing this? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted February 4, 2016 Share Posted February 4, 2016 That look like a light leak from outside, your ceiling should have a thickness and also should be touching the beams. What method of GI are you using?? Maybe your interpolation is too high or over all setting are too low. Link to comment Share on other sites More sharing options...
joaomatos1 Posted February 4, 2016 Author Share Posted February 4, 2016 The ceiling has a thickness, I modelled it in autocad. I agree, in reality it should be touching the beams; nevertheless, it shouldn't be producing this results... I'm using Brute force as the primary engine and Light cache as secondary engine. Link to comment Share on other sites More sharing options...
