palosanto Posted March 6, 2016 Share Posted March 6, 2016 Hi, I'm using vray for Rhino but it probably doesn't matter what the vray platform is. I have a scene with an environment background image set in the Environment background slot of the option editor tab. The model renders and displays fine in the VFB. But whenever I save as png, I get a transparent bacground instead of the background image. If I save as jpg, the image is complete. Where the heck did the background go ? I like the png format but in this case I don't want transparency. I don't see a choice for that. If I use a dome light instead and place the environment image there, I have no problem saving as png. But if I use the environment background option I get this problem. What am I missing ? Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted March 7, 2016 Share Posted March 7, 2016 I use 3ds max, and when i save .png files i get a popup box with some settings i can choose before saving. One of them is the option to save the .png with an alpha channel - the thing that is most likely causing your problems. I am not sure if you get that popup box in rhino, but i guess you should. Note: Sometimes saving with a transparent sky may make it easier to insert another sky in postproduction. If you use a dome light to light your scene but still want to have the sky transparent in your .png, you may check a box on the dome light to make it not affect the alpha channel. Link to comment Share on other sites More sharing options...
