kelsmith Posted May 26, 2016 Share Posted May 26, 2016 Is it possible to clamp exponential value to say, for example '200' (instead of default '255')? I'm getting white burnt areas around window and thought this solution would help. Exponential – this mode will saturate the colors based on their brightness. This can be useful to prevent burn-outs in very bright areas (for example, around light sources, etc.). This mode will clamp colors so that no value exceeds (255, or 1 in floating point value) Thanks for reading. Kelvin. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 26, 2016 Share Posted May 26, 2016 have you tried reducing your light intensity?? if Exponential can't clap it, it may mean that it is way too strong. Try Reinhard with a very low burn value instead. Or you could use any other clamp color options in VRay too. But to me, your light it is too bright or you are using bright colors. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted May 26, 2016 Share Posted May 26, 2016 You can clip it to 200 using the "clamp output", if that's what you mean? It'll look crap though. If you set clamp output to .79 it should clamp the highest values at RGB 201. I don't advise this. Link to comment Share on other sites More sharing options...
kelsmith Posted May 27, 2016 Author Share Posted May 27, 2016 Thanks for your replies. I see what I'm asking for is ill-advised. I'll have another play, see how I fair. Thanks again. Link to comment Share on other sites More sharing options...
