enriquesifuentes Posted June 17, 2016 Share Posted June 17, 2016 Hello, This is my first post in this forum. I am rendering this interior scene. I am using Maya - Mental Ray 2016. I want to get rid of these white hot spots . The image i am attaching is not completely rendered but you can tell the undesirable white hot spots. Thank you for any advice. Link to comment Share on other sites More sharing options...
Joel Gray Posted June 23, 2016 Share Posted June 23, 2016 I use 3ds Max but the principals should be the same. I'm guessing you have too few light samples in one or more of your lights and that's how you get the undesirable disco light effect. I've also had this happen with bright lights passing through glass objects. It's possible your light fixtures with the glass shades are causing this. Maybe try rendering without the light fixtures in the scene and if that's not the problem then check your light samples. Link to comment Share on other sites More sharing options...
enriquesifuentes Posted June 23, 2016 Author Share Posted June 23, 2016 Thank you Joel Gray Link to comment Share on other sites More sharing options...
