barnaimre Posted November 22, 2016 Share Posted November 22, 2016 Hi Im new in 3D, I need to do matte painting in speculative architecture for my project, at the moment I don't understand how can the resolution of the 3D model surface match later on in PS with image texture. I can setup the resolution due to " Make Unique Texture" option in Sketch up, however I haven't got any clue when I create the dimension of 3d model in meter according to the picture which I will use for texturing later on in PS, which it appears in cm and the picture usually bigger than the 3D model, therefore the image even, if I scale it down, don't match with shape. How can I eliminate this problem Thanks Link to comment Share on other sites More sharing options...
SkylineArch Posted November 22, 2016 Share Posted November 22, 2016 I'm not quite sure what you are asking for, but if you are trying to paint a texture to use on a surface in SketchUp, you can take that surface and view it in an elevation view and save 2d image, print it to a PDF, or, if you don't have the pro version of SketchUp, simply grab a screen shot, then take that into Photoshop and paint in the texture to the shape. If you need scale, you can place a grid texture in Sketchup to a specific scale,or setup guides, and resize the image in Photoshop to a real world size, but be careful the resolution. A 3 meter x 3 meter image in Photoshop will create a huge file size if the DPI is too high. If I'm completely off on what you are asking for help on, I apologize. Link to comment Share on other sites More sharing options...
barnaimre Posted November 22, 2016 Author Share Posted November 22, 2016 For the project I need to create an A2 size matte painting. I want to paste in building front side as texture on the face of the 3Dmodel a in Photoshop, I just don't know, how to optimise the scale in sketch up for photoshop to match later on with the image. And apologise I didn't mentioned that I want to keep 3D model, so I export it in obj format for PS, therefore Im looking 3D option Link to comment Share on other sites More sharing options...
barnaimre Posted November 23, 2016 Author Share Posted November 23, 2016 Sorry if wasn't clear, I need to create a A2 size matte paint, I create for instance with (x)100m; (y)75m (z)50m dimension a 3D model, and export it in obj format, and than I open it in PS as a A2 document size it generates next dimension x100mm y75mm z50mm. So basically it appears quiet small, I understand I can increase the size but than scale ratio change. what I want is to pull a high resolution image of building face to the front part of 3d model to fit with quality loss of the image, just don't know how. Link to comment Share on other sites More sharing options...
joneytran Posted December 6, 2016 Share Posted December 6, 2016 How to optimise the scale in sketch up for photoshop to match later on with the image? Link to comment Share on other sites More sharing options...
