ryanlewis1 Posted June 7, 2017 Share Posted June 7, 2017 Hi all I am in the process of recreating an underground scene and have noticed that there is a blotchy effect on all of the materials (image attached) DO any of you guys have any suggestions as to why this is happening. Thanks Link to comment Share on other sites More sharing options...
pablovergara Posted June 7, 2017 Share Posted June 7, 2017 Check that you're not forcing vray too much by lighting your scene correctly. Then check your GI settings. It looks like an irradiance map problem. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted June 7, 2017 Share Posted June 7, 2017 yea, that's GI problems usually, a larger interpolation on the IRR would fix that, but when you increase the interpolation you also need to increase the samples numbers or you would lose details. As mentioned by Pablo, this is more common when lighting is very dimmed and GI has to work double. I would try Brute force in the firs pass and LC as the second bounce. Use a large number on LC, it is very cheap for still images, so 2600 samples or more should help brute force Link to comment Share on other sites More sharing options...
ryanlewis1 Posted June 7, 2017 Author Share Posted June 7, 2017 Thank you for your responses. It was indeed bad lighting. There was a dark hdri attached to the dome light, once removed the blotches disappeared. Thanks! Link to comment Share on other sites More sharing options...
Graphite Posted June 15, 2017 Share Posted June 15, 2017 2600 Samples for LC is way to high. I've never kicked it past 1200. Properly balanced Samples for lighting and materials will help keep images looking clean and render times down. Step in Increments of (x2) starting at 32 (IE: 32, 64, 128) Interior Images hardly ever need Antialiasing, so I keep it off. Global DMC set at 64 Min Samples Irradiance Map in the GI Set to Med. Preset I use these settings as my base. Render times are pretty quick for even large scenes at 1920x1080. Link to comment Share on other sites More sharing options...
