patrickfryer Posted December 14, 2017 Share Posted December 14, 2017 Hi forum.. Im rendering in Vray for Rhino. My windows are reflecting the sky as black. Other reflections are working. Glass is using the standard vismat 'clear_glass Architectural'. Sky is a bitmap in the environment refraction / background layer. Sun is on. Any ideas what i might be doing wrong? (Is it best to do sky this way, or better to use a skydome? The sunlighting is most important for me - can you still use the sun with the dome?) Thanks people! Link to comment Share on other sites More sharing options...
Andrew _GF Posted December 23, 2017 Share Posted December 23, 2017 Maybe the brightness of the bitmap in environment is too low for the reflection to be visible. In general it is the best to use light-Dome with HDRI/EXR map inside for reflections, but if you want to keep this setting, try to multiply the output of the bitmap in environment. I think just setting the multiplier in environment won't help, I didn't use it for a long time Link to comment Share on other sites More sharing options...
