Faheem Khan Posted November 4, 2019 Share Posted November 4, 2019 hi everyone Can anybody please help me how can I do this ? I have modelled chocolates and tray, but want to put different chocolates in the tray just like this. It should look natural just like the reference attached. I have searched the web too much, but could not find any easy solution. I would really really appreciate if someone please help me in doing this. Thanks in advance Faheem Link to comment Share on other sites More sharing options...
James Vella Posted November 4, 2019 Share Posted November 4, 2019 use massfx Link to comment Share on other sites More sharing options...
Raymond Prater Posted November 7, 2019 Share Posted November 7, 2019 Wow, thx for the link, it helps me too Link to comment Share on other sites More sharing options...
Faheem Khan Posted November 7, 2019 Author Share Posted November 7, 2019 Thanks a lot, i helped a lot. But i knew that already, i was looking for more easiest way Link to comment Share on other sites More sharing options...
James Vella Posted November 7, 2019 Share Posted November 7, 2019 Glad it helped you Raymond. Faheem, In my experience massfx is the 'easiest way', takes less than a minute to setup and very little settings required for decent results. There are other tools you could use, houdini engine, tyflow, pflow, thinking particles etc, but these are not so simple and can be quite time consuming. Can you explain which part of using massfx is difficult for you, maybe there is a way to optimize your workflow to get faster results. Link to comment Share on other sites More sharing options...
Faheem Khan Posted November 7, 2019 Author Share Posted November 7, 2019 Yes you are right at every point. I tried nothing but massfx, chocolate boxes fall perfect in to closed glass, but when i try to fall the same boxes on a curve tray, they dont fall on the tray rather but fall of the floor(0,0,0). I wastched many tutorials and followed exactly that. But could not get fair result. There is another issue, when boxes fall in closed glass or tray, they collide with eachother and penetrate in to each other Link to comment Share on other sites More sharing options...
Jose Negrete Posted November 8, 2019 Share Posted November 8, 2019 It sounds like the collision type for the bowl may be set to the wrong type and it's simulating as a solid volume. Link to comment Share on other sites More sharing options...
Faheem Khan Posted November 8, 2019 Author Share Posted November 8, 2019 I will check and share a screen shot here. Link to comment Share on other sites More sharing options...
