SandmanNinja Posted June 1, 2008 Share Posted June 1, 2008 plain material with mrSun and mrSky HDRI in environment, with glass material HDRI in environment, with mirror material Hi... This is a very basic model of the Sears Tower in Chicago. I've made the walls (I got the dimensions from the internet and from google earth by measuring the base), then cloned the model and applied a lattice modifier to the clone to get the exterior 'shell'. I'm wanting to put reflective windows in there, but if I use A&D Glass (I've tried all three), the building becomes see-through. I've used Architectural material (Mirror) in the bottom render, just to reflect something. I've put a HDRI in the environment slot to give it a bit of realism. Can someone please advise me on a good way to get glass to reflect but not be like a mirror or point out where I'm going wrong? Do I need more 'environment' to reflect? Like other buildings and such. Thanking you... Link to comment Share on other sites More sharing options...
Claudio Branch Posted June 1, 2008 Share Posted June 1, 2008 (edited) I'm wanting to put reflective windows in there, but if I use A&D Glass (I've tried all three), the building becomes see-through. Your building has not become see-though. It appears that way because of the uniformity of the image you have chosen to use in your environment slot. If the surface were truly see-though, then you would see the lattice work on the backside as well. Can someone please advise me on a good way to get glass to reflect but not be like a mirror or point out where I'm going wrong? Reduce the amount of reflectivity on your material and add a noise modifier to your materials' bump slot. Play with the settings until you get some subtle distortion on the reflections. Most buildings with glass surfaces show this type of distortion because their surfaces are not completely flat. Do I need more 'environment' to reflect? Like other buildings and such. Try using different images to see how their reflections affect your buildings' surfaces. You can get quite sophisticated with the environment slot. Try using a hi-res photo for your background, the HDR for it's light/shadow contribution and perhaps even a third image that only appears in the reflective surfaces of your buildings. The advantage of this approach is alot of flexibility and more creative control. Edited June 1, 2008 by Claudio Branch Link to comment Share on other sites More sharing options...
SandmanNinja Posted June 1, 2008 Author Share Posted June 1, 2008 Thanks Claudio! I'll have a play with it then. Never thought about adding noise to the glass material. Link to comment Share on other sites More sharing options...
illegalalieninbeijing Posted June 3, 2008 Share Posted June 3, 2008 It always worked for me by just using the default thin glass material from the Arch & Design materials. If I do have to change something, it is often the diffuse color only. Most of the time I keep it as is. As for the environment, I let whatever 3d object is there to be reflected on the glass. Aside from the surrounding 3d objects, you can use or use it together with bitmap images used as diffuse map /opacity maps surrounding your 3d model. A good example of this is using a half sphere on top of your 3d model. Link to comment Share on other sites More sharing options...
SandmanNinja Posted June 3, 2008 Author Share Posted June 3, 2008 Thanks Cecil. I'm under major work load at the moment, but will try these tomorrow. Thin glass? Cool! So what's the difference between thin, thck and physical glass? I usually use thick glass for coke bottles... Cheers guys Link to comment Share on other sites More sharing options...
illegalalieninbeijing Posted June 3, 2008 Share Posted June 3, 2008 (edited) So what's the difference between thin, thck and physical glass? I usually use thick glass for coke bottles... I think that's how it is. Thin glass are better used for windows. Physical glass are suitable for more volume and heavy looking objects like glass blocks or glass sculpture. I think I tried the physical glass once and the refections came out some what concaved or distorted. It is like looking at those funny mirrors inside a glass/mirror houses. I think somewhere in it there is a parameter with a fresnel or falloff effect applied to it but I forgot. Here's an example where A&D glass is applied with very minimal tweaking. I used 3DS Max 9 Edited June 3, 2008 by illegalalieninbeijing Link to comment Share on other sites More sharing options...
stylEmon Posted June 18, 2008 Share Posted June 18, 2008 (edited) If you look at glass on most skyscrapers, the windows look a little wavy. I would use some type of bump/displacement map (possibly the stucco material, then smooth out the contrast of the colors) to get that wavy quality. I have a sample on my home computer, I'll try to remember to post it. Along with the noise suggestion above, this should pop the windows out and separate them from the background. Edited June 18, 2008 by stylEmon Link to comment Share on other sites More sharing options...
SandmanNinja Posted June 18, 2008 Author Share Posted June 18, 2008 very good ideas. I hope to spend some quality time this weekend and have a play with reflections. I'm modelling an environment this weekend, and that would be a good time to drop a skyscraper in to see how it reflects. Thanks - 'preciate the replies Link to comment Share on other sites More sharing options...
willrogers Posted September 21, 2008 Share Posted September 21, 2008 If you're still interested, I had a similar problem, an after alot of trial and error found adding a Lume(glass) shader to the Surface map of the A&D Thin Glass material made it alot more reflective of the environment. Link to comment Share on other sites More sharing options...
nisus Posted September 22, 2008 Share Posted September 22, 2008 Hi All, To have nice reflections you need something nice to reflect, i.e. use a nice 'background' (not a plate, but a spherical environment). The MrSky is not detailed enough for this (unless you add clouds). Also beware of your point of view. When you are high up in the sky, any glass LOWER than the camera will not reflect sky. rgds, nisus Link to comment Share on other sites More sharing options...
willrogers Posted September 22, 2008 Share Posted September 22, 2008 Hey Will, Do you mean surface as in 'diffuse' slot or as in the MR Connection rollout? Regards Bri I used surface in the MR Connection rollout, under Basic Shaders. Don't really understand what this does, but it work for me! Cheers Link to comment Share on other sites More sharing options...
SandmanNinja Posted September 22, 2008 Author Share Posted September 22, 2008 Wow - I continue to learn stuff. Thanks Bri and all... Bri - when are you releasing a new MBM MR video? Link to comment Share on other sites More sharing options...
willrogers Posted September 22, 2008 Share Posted September 22, 2008 A simpler workflow and one carrying less overhead would probably have been to use the Mental Ray material type and put the Lume shader in the 'Surface' rollout there! Haha, there you go! Thanks alot! :-) Link to comment Share on other sites More sharing options...
madhavan Posted August 3, 2009 Share Posted August 3, 2009 hi am new to cg community need some materialslibs for meteal effect rgds madhavan Link to comment Share on other sites More sharing options...
Nic H Posted August 3, 2009 Share Posted August 3, 2009 here are some great animal textures for you. http://www.cgtextures.com/textures.php?t=browse&q=1465 Link to comment Share on other sites More sharing options...
madhavan Posted August 4, 2009 Share Posted August 4, 2009 thanks need your help to make metalic shades like alluminum/silver /gold in max materials Link to comment Share on other sites More sharing options...
SandmanNinja Posted August 4, 2009 Author Share Posted August 4, 2009 Hi Madhaven, First, 3ds max ships with some nice A&D metal materials and second it's probably better to start a new post rather than making a post about a completely new topic in someone else's old thread. You might get more responses. http://www.mentalboutmax.com has an entire series of video tutorials on making materials such as ice, wood, water, cloth, etc. The brand new max (2010) has Mental Mill, which lets you do this as well Link to comment Share on other sites More sharing options...
Spooner04 Posted August 4, 2009 Share Posted August 4, 2009 here are some great animal textures for you. I LOL'ed Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted August 4, 2009 Share Posted August 4, 2009 It always worked for me by just using the default thin glass material from the Arch & Design materials. If I do have to change something, it is often the diffuse color only. Most of the time I keep it as is. I'll second using the thin glass preset over physical or solid, especially for towers. It is easier to predict and control what the results will be. Link to comment Share on other sites More sharing options...
Stan Zaslavsky Posted August 24, 2009 Share Posted August 24, 2009 i found Promaterials Glass shows better transparency without additional internal lighting however if you have interior lighting set up - then A&D thin glass is the way to go Link to comment Share on other sites More sharing options...
