Numenus Posted April 21, 2010 Share Posted April 21, 2010 The last Alpha version of Augenblick MMV, a real time based renderer is currently available as a free download http://www.numenus.de/produkte_en.html The next one will be the beta! It would be great if you give it a try and of course we love to hear your feedback! Link to comment Share on other sites More sharing options...
JonRashid Posted April 21, 2010 Share Posted April 21, 2010 I have tried both 32 bit and 64 bit. They both fail on extract with a 1152 error. Windows XP error occured on 2 separate machines Link to comment Share on other sites More sharing options...
Numenus Posted April 22, 2010 Author Share Posted April 22, 2010 Hi, I just went to the CG lab at the university to check several machines (as our developer machines work of course ) I tried several boxes with Win XP, Vista and Windows 7 and could not reproduce the problem. However it seems to be related to the new install shield installer we are using since that alpha version. So I can just make a guess: Do you have sufficient disk space on your primary partition - as the installer tries to copy something to a temp folder. What language are you using in your OS? I only tested german and english. Link to comment Share on other sites More sharing options...
JonRashid Posted April 22, 2010 Share Posted April 22, 2010 Thanks for prompt reply. Just tried install at work and it works fine. I have no idea why it didn't work on home PC's as they are extremely high spec. Thanks anyway will get back to looking at the software Link to comment Share on other sites More sharing options...
ihabkal Posted April 22, 2010 Share Posted April 22, 2010 it didn't work probably because you have a firewall or the usaer control shiled in vista/win7 is preventing it Link to comment Share on other sites More sharing options...
JonRashid Posted April 22, 2010 Share Posted April 22, 2010 Windows XP and certainly not the firewall. If it was a security issue it would have come up a work for sure. The error code should give some sort of indication and it was while it was trying to write one temporary file. Once the extraction has started you have already passed the firewall. At that point it can only affect outgoing communication from the software. Link to comment Share on other sites More sharing options...
