videogamer22 Posted December 13, 2010 Share Posted December 13, 2010 Hi everyone, I'm fairly new to Max and am using 2011 Student Edition. When I use the daylight system and mental ray, the roof of my room will not render:confused:. Can some one find a solution?Thanks[ATTACH=CONFIG]40412[/ATTACH][ATTACH=CONFIG]40411[/ATTACH] Link to comment Share on other sites More sharing options...
jinsley Posted December 14, 2010 Share Posted December 14, 2010 does your roof have any thickness? or is it a polygon? if its a polygon are the normals facing the right way? Link to comment Share on other sites More sharing options...
TSuess Posted December 15, 2010 Share Posted December 15, 2010 Under the Common tab of the Render Setup Dialog check Force 2-Sided. Or use the shell modifier on the plane representing your ceiling. Link to comment Share on other sites More sharing options...
amer abidi Posted December 15, 2010 Share Posted December 15, 2010 yeah, you most probably cloned your floor plane up to fill the ceiling, which is ok as long as you know that now your ceiling plane normals are facing the sky, not the other way around (which should be the case). So you have to flip the ceiling planes normals. Many ways to do that, simplest is just to mirror it on it's own z axis. Applying an edit poly modifier and flipping the normals after selecting the face(s) also is a simple workaround. Applying a shell modifier as mentioned earlier will fix the solution, but will also add a thickness to you ceiling. Link to comment Share on other sites More sharing options...
