Animated curtain following a trail in 3D Max
I'm making an animation of a curtain following an irregular shaped trail.
A bit of research pointed out that the best approach would be to use cloth, attached to rigid bodies and moved with reactor.
I don't have any clue on how to implement this though, since I'm not familiar with reactor. I found this video already, which points out more or less what I want to do;
Can you help me out?
  • 2 weeks later...
Actually creating a cloth and fixing it to some hooks isn't difficult with the built in cloth generator. Moving the hooks along a curved path and let the cloth act accordingly is already more difficult.
I tried with a path constraint but the problem is that I have to move each hook through a different path constraint controller on the motion panel if I understand right.
Is there a more straightforward way to attach the hooks (and the curtain) to a path?
Edited by Mazinger
